跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
问题已关闭
Ring/ Vibrate Switch function
My daughter's iphone had a busted digitizer and a cracked back so I decided to refurbish it with new glass/digitizer and rear case.
I used the excellent resources on this site and the disassembly was smooth.
Just a couple snags. Trying to re-install the Ring/Vibrate switch was a difficult in that it didn't want to stay in position while I was reinstalling the ribbon cable with the Switch. It would work once or twice and then would pop out of the switch. Finally it stayed in, but the switch itself no longer protrudes from the case, but is totally flush making it hard to use without a spudger. Is there a trick for getting the button in place and working properly?
Similarly the power switch protrudes about half what it did.
Any good tips?
jb
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I did this replacement also and on the power button at least I found out that the metal loop attached to the power button has to be down for it to work correctly. I put it up and it only stuck out about half as far.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 706
