跳转到主内容
Republic of Gaming laptop released in 2015 . The GL551J has a GeForce GTX 860M video card and a 15.6" Full HD 1080p display.
18 个问题 查看全部
Won't support windows And/Or any other explo systems.
Hello Dear,
My pc has taken a hard shock, by falling under the table.
after, he shut down. And wont boot up, by showing a message : that he doesn't find any exploitation system to boot up with.
i tried too many time to format it but with no answer. it shows blue death screen after the format ends.
after that he stops even completing this format and shows : Error 0x8004245F
And for the temperature its always high. but it works with "Linux Live" for some time, about 30 minuts.
i tried to scan it with linux, gives that the problem is in the temperature but sometimes in the HardDisc.
Please help me solve this problem, and thanks alot for your help i really appreciate you hard working
thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @abdellm, since you mentioned that your laptop has encountered a hard / drop shock, most probably the hard drive is damaged.
Try accessing the laptop BIOS and check if there are any diagnostic test for HDD.
If the laptop is still under warranty, send in for service.
else you will need to replace the HDD, just follow ifixit instructions for it, if you have some budget, go for SSD drives.
这个答案有帮助吗?
得分 2
1条评论:
Hi @salmonjapan, Okey thank you so much for your responding. i will check it then i'll send back to you, for any other exo problems
完成的
添加一条评论
添加你的答案
Abdellm 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 129
