跳转到主内容
Panasonic Lumix DMC-FZ35 High-end Digital Camera - Black DMC-FZ35K 31
4 个问题 查看全部
Dead, no power on
I have the Panasonic Lumix DMC-FZ35 High-end Digital Camera - Black DMC-FZ35K.
I am trying to turn it on but it is not working, totally dead. I replaced the battery, tried to turn it on but no luck, nothing gets turned on, totally dead. I don't know what is the problem. Can you advise me what part needs to be replaced to solve the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Same problem - I was hoping to find a secret button combination on power-up that would put this camera into a diagnostic or reset mode.
完成的
添加一条评论
1个答案
最有帮助的答案
@geomorzak there is no specific part that may have failed. You do want to make sure that your battery is okay and that the battery makes proper contact. Make sure that the battery cover closes properly and that the battery contacts are not bend, broken or corroded.
After that you are bound to have to take the camera apart. You can start with this guide Panasonic Lumix DMC-FZ35 LCD Replacement to at least get you into the camera. Of course you can also use these instructions DMC-FZ35-Disassembly.pdf
Now check your circuit boards for any damaged and/or missing components. Pay particular attention to the main PCB around IC1001 which is your power supply IC. Post some images of your circuit boards once you have it apart. We can always try and help you with further troubleshooting. Use this guide 在已经存在的问题里加入图片 for that.
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
Panasonic Lumix DMC-FZ35 DMC-FZ38 LCD图片
指南
难度:
中等
30 minutes
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
George 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 1,415
