Your Xbox One console may unexpectedly turn off under the following circumstances:
The console is too hot.
There's a problem with the power supply.
Reset your internal power supply
The Xbox One S and Xbox One X have an internal power supply that works in all regions worldwide. If your console won't turn on, it may simply need a power reset. Often, power issues are due to the power supply resetting after a power surge.
To reset the internal power supply, follow these steps:
Unplug the power cord from the console.
Wait 10 seconds.
Plug the cord back into the console, and then press the Xbox button on the front of the console.
or perhaps your power supply is clogged and overheating...
Xbox One 电源适配器 (首发限定版) 拆解
There are some more links and details in the Xbox One Turns Itself Off wiki.
33条评论
I had this same issue I saw a few post about doing the hair dryer trick but i didnt want to take mine apart. I just used my vacuum using the tube tool and made circles from the outside on the shell where the fan is for like 10 secs. Then it turned on with no issues
由 Joshua Winter 完成的
Also open your system up and clean the inside look for any foreign objects around the power button area ,I did this and my system works fine now.
由 penderdevaughn 完成的
my xbox sill wont work
由 jackson.lee25 完成的
Hi my xbox turns off as soon i try turn it on i toke vacumm to outside of it still nothen i check power cord its fine i even plug it in to nother power source nothen i toke xbox apart check top of fan and around it nothen but small amount of dust i toke small screwdriver i could spin fan . I watch it as i try to trun it on it just beeps and shuts off fan didnt move a inch like most would do soon you trun it one . Would any know what is worng with my xboxs.
由 Billy Harris 完成的
My turns off no matter what Microsoft please fix this no matter what I do it turns off no matter what
由 Darth Pequin 完成的
显示更多的28条评论
