跳转到主内容
任天堂3DS XL 2015在市场上被称为新任天堂3DS XL,于2014年10月11日在日本发布,2015年2月13日在北美发布。
369 个问题 查看全部
New 3DS XL power button light turns on and then turns off.
So, I just got done fixing my 3DS however it appears that It won't power on, it doesn't make any noise, or do anything, the power button goes on for a bit, and then just turns off, the only thing not connected are the speakers (broken ribbon cable connector)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
5条评论
you said you were done fixing it what did you fix?
完成的
I fixed the shoulder buttons, however I also took out the motherboard and other things as I was going to replace the broken touchscreen however now I'm not sure. it's assembled at the moment.
完成的
My cousin had the same issue after replacing the battery. The problem was corrected by blowing out all the cable connections and then replacing them.
完成的
"Blowing out all the cable connections" Elaborate please.
完成的
The ribbon cable connector that is soldered to to speakers is what connects the motherboard to the top screen, so that may be your problem. Replace the broken cable.
完成的
添加一条评论
6个答案
最有帮助的答案
From my personal experience this happens from the camera flex not be connected 100% but it really could be from really any connector or flex being damaged, I mean did you try to flip up any of those connectors while you were in there? I've done it once and I obviously ended up in the same position as you from it. I'd just go back in and unplug and replug your connections and make sure they're latched on by pressing on them a bit once you're sure they're in correctly. On the bright side you were just working on the bottom half and it'll make easier to double check everything. Please let us know what happens!
这个答案有帮助吗?
得分 1
添加一条评论
If it is from gamestop, it may not be charged.
这个答案有帮助吗?
得分 0
添加一条评论
Try reseating your ribbon connectors. Chances are you didn’t fully insert one or two of them, causing the system to fail POST, which has the result of immediate shutdown.
这个答案有帮助吗?
得分 0
添加一条评论
I had this same issue and all I did was loosen all the board screws and it started working.
这个答案有帮助吗?
得分 0
添加一条评论
I have this same issue too. My speaker ribbon cable broke, could this be the reason to my 3ds not turning on?
这个答案有帮助吗?
得分 0
添加一条评论
Yes, if the ribbon cable is not functioning the system will not post and there fore will not turn on
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
RoastedHotdog 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 20
过去 30 天: 45
总计 4,507
