跳转到主内容
Released in 2015, the all-in-one camera featuring WiFi, Bluetooth, touch screen display, and waterproof capabilities.
31 个问题 查看全部
My Gopro HeroPlus lcd, back lcd is broken
Can you purchase a new rear touch screen and replace it ? My one is broken/cracked
If you can, Is there a tutorial to show me how ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thank you for your quick response, hopefully I can find an lcd replacement, if I do, I’ll post where to get it from.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @chrisjohn ,
This is only half an answer to your question.
Here is a link to a video that shows how to remove the LCD screen from your camera.
If you do decide to follow this video ensure that you disconnect the battery before attempting to disconnect the video cable and remove the screen. Also reconnect the battery after you have replaced the LCD screen and connected the LCD screen cable.
I've searched online but cannot find a replacement lcd screen for a Go Pro Hero + LCD camera. You may have better luck. If you cannot find one either, check if there is a part number stamped on the back of the lcd screen in your camera. If there is, search online using just the part number only and see if you get any results.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Chris john 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 60
