Good and often decalcification and general cleaning inside the machine will prevent most issues. When water, (some but not much) comes out of the steamer when it’s not supposed to (e.g. during the brewing process), the first thing to check is the steamer assembly (behind the control panel) including where the water “hose” that feeds the steamer is coming from. But generally speaking, regular decalcification/cleaning is the best prevention.
ALSO, if anyone knows a website how to calibrate the coffee grinder, please let me know my email is R1100R (at) gmail (dot) com (<— written this way to deter spamming). I am not talking about the external rotating button in the hoopper that goes from 1 to 7 in about 13 clicks. I mean the entire assembly underneath. I had to remove it and clean thoroughly as some beans were stuck in there and blocking the machine from working. Apparently there is a “trick” putting the grinding mechanism back together which I am not aware of. Help me please if you can.
There is only one service location in my area (NW Chicago subburbs), but it is ~2 hours away from me, it is not a DeLonghi facility but a 3rd party company, and they charge an arm and a leg (~$100 just to walk in the door to drop off the machine (they call it “diagnostic fee”) plus another $100 per hour labor, plus of course extra for parts which they do not have all of them always available. I love my ESAM3300 but service and parts is such a big problem. When this one kicks the bucket I am trying a different brand for sure.
Thank you!
Thank you for your response. I spoke to someone who told me how to determine the number of espresso shots that the machine has made. Mine is over 27,000. In addition, with the machine off he had me open the front door, take out the brewer unit and look at the yellow cylinder at top right. This had water in it, which I guess is not good.
Based on number of shots made and repairs needed I ordered a new machine. I'm now on my 3d Magnifica.
由 bob 完成的
27000 in three years - not bad!
Yes, the yellow cylinder is what I called upper piston, and yes it seems to be the reason oft your issue. Give it a try, open it, its not too difficult. Use this site
https://www.juraprofi.de/Service-Anleitu...
and download https://www.juraprofi.de/anleitungen/DeL...
Google translate ( or I) will help you.
由 VauWeh 完成的
So I decided to just buy another Delonghi 3300. I noticed I have a small pile of grounds inside the machine between the infuser and container that collects the used pods. Why and is this something I should have looked at?
由 bob 完成的
@vauweh do you know where can i find the screw for the clamping piece? Thank you for the link to the guide. I stripped the screw for the clamping piece.
由 sheilamoo 完成的
