跳转到主内容
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 个问题 查看全部
How to install ps3 firmware from pc to ps3 hard drive directly
The real problem is with the bluetooth/WiFi card. It wasn't working before the system update. and it's soldered to the ps3 board "hard to be replaced " .
i search for any other way to complete the update without replace the chip
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Did you find a solution bro?
这个答案有帮助吗?
得分 0
添加一条评论
you can remove the hard drive and buy a sata to usb adaptor
and connect the hard drive to the laptop or pc and transfer the file and reconnect it to the ps3 or you can just put the file on a usb stick and plug it into the ps3 and transfer files for update
这个答案有帮助吗?
得分 0
1条评论:
does this still work and do i do PS3 \UPDATE \.PUP
or just put .pup straight into hdd
完成的
添加一条评论
添加你的答案
mohamad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 28
总计 3,344
