跳转到主内容
问题已关闭
Bluetooth unavailable after opened up the back
I bought an Optibay drive to install a SSD.
After putting everything back (And I'm sure that everything's backed)
No problems at all except my Bluetooth became unavailable, may I know how can I fix it ? I tried every solution posted on web including repairing disk permission, double check all the preference panes thing, logged in as root user to repair and so on.
I suspect that it's the hardware problem, but I don't know how to fix it, kindly give me few advice please.. I really appreciate it :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I think you are in the same situation as I do.
There is a cable running from the logic board to the screen, along the optical drive bay. The connector to the logic board is realy not robust and may have been broken.
You may try to disconnect it and look if there is any damage.
If so you are in trouble becaus this cable is splitting in two at the bottom of the screen panel. One half goes to the Wifi/BT and the other is going to the camera.
Why does my wifi not come up (the camera doesn't work either)?)
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,433
