跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4682 个问题 查看全部
Why does my iPhone show 10 percent more when I restart it?
Why does my iphone show 10 percent more when i restart it?
i think it just doesn't show the correct battery percantage because wehn my phone is at
10% i get more than 10 like 20
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
Thank you so much I didn’t even know the app existed i have a windows and i tried to downlond the coconut thing but it said only mac and now i tried other one very helpful
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
3个回答
已选择的解决方案
This could be caused by a weak or weakening battery. You should download coconutBattery (Mac) or 3uTools (Windows) to test the health of your battery. If it shows less than ~70% Design Capacity or Health, that's a sign of a weak battery.
Replacing the battery is easy, just follow this guide.
这个答案有帮助吗?
按维修分数 3
评论:
This can also be due to extreme temperature, either on the hot or cold end. The temperature can cause variability within the battery controller. Restarting the device will allow the battery controller to get a new readout.
添加一条评论
Sounds like the iPhone is not reading the battery percentage correctly.
I recommend first trying to restore the iPhone, make an iTunes backup of your phone first before doing so.
See if that helps.
Then if it doesn't help try replacing the battery as specified from the other answer.
这个答案有帮助吗?
按维修分数 1
添加一条评论
The battery percentage is only an estimate. Your phone doesn’t know the exact percentage of the battery, so when it restarts, it re-“guesses” the percentage, which may be different than the “guess” before it restarted. This may not be the case, or it could be a combination of this and a bad battery.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
CHAIZY 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 9
总计 140
