跳转到主内容
Repair guides and support for riding lawn tractors sold under the Murray brand name, currently owned by Briggs & Stratton.
139 个问题 查看全部
Starts but won't stay running
I was given the mower, it's been sitting s while. So I've replaced battery, selenoid, cleaned air filter, new gas(was empty). If I spray started fluid in under the air filter it will start but won't run. I also put carburetor cleaner in the gas tank but a half dozen cranks later over the next 30 minutes it still won't start. Not sure how to get to the carburetor and how to clean it if I do. Looked through many diagrams here with no luck. Help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
You have a clogged carb, need to pull it off and clean it, most likely it is located under the seat if it is a mower like the one pictured. Also, if you follow the gas linie out of the gas tank it should lead you right to the carb.
Please post model #
这个答案有帮助吗?
得分 0
2条评论:
Murray Select model number on motor is 283707. I think I see it behind the frame, where the gas line goes into it. There's a cup like cylinder on the bottom. I guess take the nut off that and clean?
完成的
https://www.ereplacementparts.com/briggs...
Take off part 975A, to see if the fuel is gummed up, etc...then post back.
完成的
添加一条评论
Remove carb. Clean carb and all internal parts float, jets, needle valve ect. Replace any gaskets if needed. Put carb back on and it'll run.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andy Dosdall 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 82
总计 9,432
