跳转到主内容
Released in October of 2014. This model, SM-G530H/DV Samsung Galaxy Grand Prime, comes in a White, Gray, or Gold casing.
148 个问题 查看全部
Why doesn't my Samsung device recognize the micro SD card I install?
On my Samsung Galaxy Grand Prime, Model#: SM-S920L, why won't it recognize when I install a micro sd card for expanded memory? I've tried an HC 8Gig card as well as a Samsung brand 32Gig card but it won't read that there is a card in there at all. Is the reader damaged? The prongs of the reader have to meet the pads on the sd card, right? So maybe the prongs are bent? How can I fix this issue PLEASE!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
The phone appears to be dual sim, with the main sim reader having a microSD reader at the top.
My guess is the microSD card reader pins have been damaged or bent.
Unfortunately if this is really the case a new one would need to be resoldered on.
Not much people would do this as a rework station is needed, if you can find someone that does micro-soldering they can do this for you.
I think you should be able to visually inspect for damage easily with the use of a microscope and looking into the slot with a light source.
这个答案有帮助吗?
得分 2
2条评论:
Thank you, Ben. I appreciate that. Is there no way of simply bending them back into place if they've just been bent?
完成的
Yeah you can with tweezers but you would have to be very careful, bending them back too much may cause one or more of the pins to break off.
完成的
添加一条评论
最有帮助的答案
Hi,
Just double checking that you have inserted the card(s) until they 'click' into place and that to remove the card(s) you have to push it in further so that it springs back out.
Also have you tried mounting the SD Card?
Go to Apps > Settings > Storage > tap Mount SD card.
这个答案有帮助吗?
得分 2
3条评论:
Thanks Jayeff, for your response. I have inserted the cards fully each time and the option to Mount SD Card is grey'ed out in the settings. That's my problem. The phone doesn't recognize that one is present when it clearly is.
完成的
Hi,
Has it worked before OK?
My only thought is to try a factory reset just in case it is a software glitch that is causing the problem and not as you are probably correct in saying that it is a hardware fault. Initially it is less intrusive than having to open the phone and possibly causing more problems
If you do decide to try this remember to "back up" the phone first. That way when you wish to restore the phone after the reset has either proved or disproved whether it is hardware related or not you can go back to where you were before you started.
完成的
Format the card
完成的
添加一条评论
添加你的答案
Grayson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 30
总计 13,876
