跳转到主内容
This digital camera was announced by Panasonic in January 2014. The Panasonic Lumix DMC-ZS40 has a 18 megapixel sensor and built-in GPS features.
7 个问题 查看全部
Panasonic Lumix DMC-ZS60 will not power up
Hi. Camera got slightly wet on a boating trip and would not turn back on. Pulled the battery and tried to charge it but no response from the camera. Would the water have killed the battery? Or is it something inside the camera?
Don
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The water shouldn't have killed the battery, but if it wasn't removed as soon as possible after the camera got wet then it may have caused electrolytic corrosion in the electronics, or damage due to current flowing where it shouldn't. Disassemble it and clean all the electronics with isopropyl alcohol and you might just be able to recover it. But if the water got into the lens you may have trouble sorting that out.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Donald Cheeseman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 341
