跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
873 个问题 查看全部
Can I replace the entire rear housing?
I broke the rear glass on my iphone 8. It looks really hard to scrape off the glass and replace that part, so I was wondering if I can replace the entire back of the phone? I could just take out all the parts and transfer them, but the wireless charging coil looks like it's near-impossible to remove successfully. Does anyone know where I can purchase a rear housing including the wireless charging coil? Am I even on the right track with this?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
4个答案
最有帮助的答案
You can do it yes.
How to assemble iPhone 8 back housing?
这个答案有帮助吗?
得分 6
3条评论:
Do you know where I can buy the part including the wireless charging coil?
完成的
The wireless charging coil can be removed, heating it with the heat gun can make it easy to be removed. The iPhone 8 backhousing is not available now.
完成的
Mobile sentrix OEM Pulls
But also I heat the back of old housing and crack at glass making wireless charging coil come off or fall out
完成的
添加一条评论
I have kind of the same problem, but - yet still a little worse:
My iPhone 8 has been dropped on a parking lot with an uneven surface - and run over by a car!
So, the entire back housing is bend quite a lot (strangely enough, neither the back glass or the screen seems to be damaged at all).
But it looks odd, and being the skilled industrial technician I am, I’ve tried to bend it back into the correct shape. This cannot be done, since the aluminium kinda hardens the first time it is bend out of shape - and cannot be forced back to its original shape.
So, it would be very appreciated if anyone could help, regarding where I can buy a new back housing.
这个答案有帮助吗?
得分 0
1条评论:
Mobile sentrix highly recommended testing the phone with new screen before attempting repair
完成的
添加一条评论
yes you can buy a back glass with mid frame and small parts installed or with a charging coil installed or just bare.
这个答案有帮助吗?
得分 0
添加一条评论
Yes you can however stuff sold in the western world is not cheap which is sourced out of china anyway but below is the link to what you are looking for.
https://www.amazon.ca/Vimour-Housing-Rep...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
fdsajky675 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 29
总计 10,401
