跳转到主内容
Device and repair information for the Dell XPS 13 laptop models 9343 and 9350, which were both released in 2015.
74 个问题 查看全部
How do I remove a (somewhat stripped) screw that is stuck?
In order to replace the palm rest I have to remove all the internal components but a few of the screws holding the motherboard in place are stuck.
How do I remove this screw without damaging the motherboard?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Sounds like you used the just slightly wrong sized philips screw driver.
This probably caused the stripped screws.
You can get a set of strip screw removal tools.
https://www.amazon.com/Moody-Tools-58-06...
Or if you have a small enough dremel you can simply remove the heads of the screws.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jelle 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 648
