跳转到主内容
Why is my camera won't turn on?
This happened suddenly, there was no water damage or shock damage. I have 2 batteries, last time i've fully charged it and now it won't turn on IF the cable charger doesn't attached. It will normally works when the cable is attached, the camera would turn on and works fine and the battery indicator shows it fully charged, but doesnt charge at all, and when i unplugged the cable it will shut off immediately. Same thing if i plugged the cable, it won't charge at all even if i didn't turn on the camera, it just went blank. I've tried both of the batteries and it happened the same. Does anyone knows what is going on with my camera?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
I have a similar problem with the added feature of the LED light on the flash blinks intermittently. The battery is definitely charged and the inside doesn't show any issues with the connector plates (corrosion etc) from what I can see peering into the battery slot. I'd love to try a hard reset if it existed, but from what I can read I need to be able to access the menu which is hard to do with no ability to power on! Anyway, any ideas are appreciated.
完成的
I have a similar problem with the battery.
Any ideas are appreciated !
The camera seems to not recognize the battery .... sometimes .. let me explain.
If the battery has been in the camera for awhile, many times it won't turn back on.
If i take the battery out, and put it back in, it turns on.
This is obviously not possible if it is in the underwater case and i am diving! Very frustrating ! i prepare the camera before diving, and by the time i get in the water, it won't turn on.
Any easy suggestions as to what i might try. i am on an extended diving adventure for 2 months in SE Asia with no access to an Olympus repair center.
Thanks for any ideas !
Donna
完成的
添加一条评论
3个答案
已选择的解决方案
I had the same problem, but for me it turned out to be the battery turned the wrong way. In most cameras it’s not possible, but in the the tg5 it is.
I hope it helps someone!
Marten
这个答案有帮助吗?
得分 7
7条评论:
Mark, your suggestion just got my camera back in action! I had mistakenly put the battery back in the wrong direction and couldn’t figure out why it was not working. So glad I checked this site!
完成的
Thanks so much. It fixed the problem.
完成的
Thanks a lot Marten! It fixed me issue too!
完成的
thank you very much!!! hahahaha
完成的
Best tip ever! Saved my life! Thanks a lot!
完成的
显示更多的2条评论
添加一条评论
Stylus TG-860 has same issue. Battery can be put in backwards, then it doesn’t turn on. Put it in the right way, and it comes on fine.
这个答案有帮助吗?
得分 1
2条评论:
tg-3 is the same design. Fixed by flipping the battery. But tg-3’s screen won’t light up when charging, if the battery is inserted the wrong way.
完成的
My Batteries are in correct, and still no power, the camera is an older Olympus C4040 Digital, and I have unable to find anyone that repairs them any more. Bummer because the camera is in brand new condition, not a scratch or scuff on it anywhere, and It worked great a week ago, Sad, when it worked it took fantastic pictures, VERY FRUSTRATED!!! If anyone has any suggestions, I would appreciate. Duane Hampton
完成的
添加一条评论
This is so ridiculous but it's true. MY battery got reversed and when that happened the camera would not power up with either the battery or the power cord. It's just nuts that the battery can be reversed so easily without realizing it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Haikal Adlan Rinaldi 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 101
总计 14,994
