跳转到主内容
CD-Tuner with RDS and white LCD
3 个问题 查看全部
How do I turn off repeat on CD player
When I play a CD the song just plays over and over unless you press forward at the end of each tune. Need to turn repeat off somehow?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@joy100 check your owners manual page 10. It will tell you how to turn repeat track off.
Update (01/07/2018)
@joy100 it is odd that it does not enlarge. Try this on. All you have to do is to just hover over it an click on it.
What it says is :
During playback, press (3) (REP) repeatedly until "REP-ON" appears in the display.
Repeat Play starts.
To return to normal play mode, select "REP-OFF"
这个答案有帮助吗?
得分 2
3条评论:
Hello again, I cannot enlarge the image you sent, so cant see what to press!! Have tried a magnifying glass but still no good!!
Sorry to be a pain but please could you sent the image again but larger. I will be eternally grateful!!!
Cheers,
Joy.
完成的
Hi @joy100 ,
Just click on the image to enlarge it.
完成的
I have tried that but it doesn't enlarge enough for me to see it. Are you able to see what it is I press to turn repeat off Please?
完成的
添加一条评论
添加你的答案
Joy 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 41
总计 7,174
