跳转到主内容
A Windows phone known for its camera capabilities. Also known as Nokia EOS, Nokia 909, Nokia RM-875, Nokia RM-877, Nokia RM-876.
It does not charge
This phone was pretty dead and my first sight was a battery problem. I replaced the battery.
With the new battery installed, the phone could turn on but it does not charge the battery. I was using a usb charger cable.
It looked like the usb flex port was damaged. The flex port was replaced but once again, the phone still does not charge the battery.
Someone has a clue of what is going on?
Maybe some internal components related to control the supply of voltage inside of logical board are damaged. Could you give me an advice of how check this condition?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hello there
By inspecting the logic board I found the cause issue, it is a lossy capacitor.
这个答案有帮助吗?
得分 0
1条评论:
Hi David
I know it's been a while since you posted this, but hoping that you see this. I have the exact same issue and have replaced both the battery and usb assembly.
Was there anything that could be done to fix the issue with the capacitor, or was that it for the board?
完成的
添加一条评论
Hi David,
I’ve had a similar issue with my 1020, but the component (as you’ve depicted above) is a type of inductor, rather than a capacitor. If you search around, you’ll probably be able to find it for sale online.
Details:
这个答案有帮助吗?
得分 0
1条评论:
Hi Dylan, I have this same issue. Can you tell me exactly what the component is I'm looking for, or better yet a link to it? I would be very grateful! Thanks!
完成的
添加一条评论
添加你的答案
David 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 2,359
