Why can't I hear phone calls unless the speaker is on
I can not hear phone calls placed unless the speaker is on
Hi @pbplus313058 ,
Try using the earphones with the microphone attachment and listen if you can hear OK when using them on a call.
If you can and since you can hear OK when using the loudspeaker then most likely there is a problem with the phone's receiver. It's either faulty or has come loose from the systemboard
Here is a link that shows how to replace the receiver in your phone.
Here is a link to some suppliers of the replacement part. It is not a recommendation to use them. It is shown to give an idea of the cost of the part.
If the repair process seems to daunting, I suggest that you contact a reputable, professional mobile phone repair service and ask for a quote to repair the phone.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 26
总计 1,751
