跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
When I turn off my iPhone, it turns on at the moment, like a restart.
I don't know why my iphone 4s restarts when i only turn off it... The battery was changed, but in a chinese electronic shop. But i think that is caused by a problem on the motherboard, but i had been reading in some foros that it could be a problem on the dock or battery. Someone could help me to solve this problem? i would like to have a repared iphone....
Thanks a lot!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Open up the phone and unplug the power cable from the motherboard; see step 17 of this guide:
iPhone 4S Power Button Replacement
Turn off the phone. Does it reboot again? If not, replace the power button cable. If so, disconnect the dock connector cable (step 8 of the same guide as above) and turn the phone off again. If it doesn't reboot again then you need to replace your dock connector. If it does (highly unlikely) then something else is amiss.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Julio 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 26
