跳转到主内容
Sales of the second generation model started with model year 2000 and production ended with the 2005 model year. The second generation Neon was only available as a four-door sedan.
8 个问题 查看全部
Why does one windshield wiper not work?
Why does my driver side wiper not work but passenger side does?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@packergirl73 since one side works and the other one does not, this will be an wiper linkage issue. First you want to check to make sure that the wiper arm still connects properly to the linkage:
WIPER ARMS REMOVAL
(1) Place the wiper arm/blades in the PARK position and turn ignition OFF.
(2) Using a trim stick (special tool #C-4755) or equivalent (screwdriver;-), gently pry up on arm cap and remove.
(3) Remove the wiper arm retaining nut.
(4) Remove the arm from the pivot using a rocking motion while the arm is in an over/centered position.
(5) Clean metal splinters OFF the pivot shafts.
If that all looks good you'll have to check your linkage. Here is how to work on your wipers Dodge-Neon-Wipers.pdf
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Becky ross 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,164
