跳转到主内容
修复你的物品
维修的权力
配件 & 工具
This is a stainless steel, 4 slice toaster oven. The model number is located on the bottom of the device. It has a single rack height and a removable crumb tray.
8 个问题 查看全部
Why is my ON light always on even if all the knobs are off?
My toaster is brand new and i used only once. The second time, the ON light kept turned on even though the oven was off. Is there anything I can do to turn it off?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
1个回答
已选择的解决方案
Hi @csiqueirab ,
Don't know your toaster but was wondering if the timer control knob should be at the red arrow position and not at the blue arrow position as shown in the image below. Apologies if you have it already there
(click on image to enlarge for better viewing).
If this is incorrect, I suggest that you contact Black & Decker customer support either for an answer to your problem or if the toaster is faulty what to do to get a manufacturer's warranty repair or replacement.
这个答案有帮助吗?
得分 2
评论:
It worked! I can't believe I didn't see this feature "always on"! It worked! Thank you very much!
完成的
添加一条评论
添加你的答案
Camila Siqueira-Boonstra 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 43
