跳转到主内容
Repair and disassembly guides for Asus tablets.
428 个问题 查看全部
I dropped my Asus Tablet into water and it won't stop rebooting.
I dropped my Asus Tablet into water, can it still be saved? It won't stop rebooting. I have put it into rice and drying bags and it is currently drying. It won't stop rebooting, and i cannot turn it off. It is doing the same thing as my old Asus tablet. do you think it is still able to save?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Hi @escapism ,
What is the model number of your tablet?
It may be able to be repaired. It depends on what damage has occurred and whether it is economical to do the repair
You need to open the tablet and disconnect the battery from the systemboard to minimize any further damage. Once the battery has been disconnected, DO NOT reconnect it and try to turn on the tablet again until it has been cleaned and repaired, as you will only be compounding the problem.
Also while rice may be good to eat it does nothing to fix the problems caused by corrosion
Don't Put Your Device in Rice. Here's Why...
Water, electronics and electricity are not a good mixture. The impurities in the water cause corrosion whilst the water itself is a conductor of electricity and allows current to flow in areas not catered for in the circuit design of the tablet
You need to clean off all the corrosion and disperse any remaining water by using IPA 90%+ (Isopropyl Alcohol - available at most pharmacies). Do not use "rubbing alcohol" as it is usually only 70% or less, may contain scents and is not as effective.
The link below may be of some help in the cleaning process of the components affected by the water and corrosion.
Electronics Water Damage.
If the above process seems to daunting, I recommend that you contact a reputable, professional laptop or mobile phone repair service experienced in water damage repair and ask for a quote.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Yes! absolutely , but surely the other parts is for replacement.. try to open your tablet and you will see lots of corrosion. try to clean the board using brush and alcohol and try to reflash the stock rom. using SD card..
download your stock rom here....
https://www.asus.com/support/#
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Cassie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 757
