Why is one of my propelers is not working
Every time I turn my drone on one of the propelers won't work
Do you still have it?
There is a screw that goes through the propeller and the shaft, on the bottom gear you have the same set up. the screws will shear in the shaft preventing a simple replacement. You may have to drill out to free the broken screw inside the shaft, through the top worked for me
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 343
It could be the screw that holds the propeller to the shaft; sometimes the break
由 lild.james 完成的
