If BT is installed and working in the laptop (Check in Device Manager for BT status) then that's all you need (hopefully). Sometimes there is a compatibility problem between BT versions i.e the laptop may be running a different BT version number to the headphones. It should work but... e.g. I have 2 different brand mobile phones, both Android, 1 connects to my car's entertainment system via BT the other doesn't. Go figure!
Can you connect any other BT devices to your laptop?
Can you connect your Skullcandy to another BT source e.g. a mobile phone perhaps?
Hi @tngent ,
由 jayeff 完成的
