跳转到主内容
Updated version of the 2015 Retina MacBook. Model A1534, EMC 2991. Released in early 2016.
106 个问题 查看全部
Has anyone successfully replaced a battery for this?
Anyone ever attempted a battery replacement on this? I know iFixit says there’s super strong adhesive but if it’s similar to the strong adhesive on the iPhone battery, then it just seems like the same process but 5 times.
Mine is wearing out and sitting at 85-89% with about 280 cycles. I feel like the degradation is going pretty fast... (and yes, I will bring it to Genius Bar later if I can't do the fix myself).
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
评论:
That would be a pretty good guide @sam (I would do it myself but can't because I don't have any)
完成的
I guess I should amend my question: I see you all sell the MacBook 2015 battery replacement but there's no 2016 replacement. Your 2016 teardown suggests that the battery is compatible but the 2016 model battery may be larger slightly. Any chance you'll have those in stock?
完成的
Any thoughts on this @sam, now that the holidays are over? :) Coconut battery is reporting that my battery is degrading at a precipitous rate (82.9% atm and was at 87-89 when I wrote this initial post)
完成的
添加一条评论
1个回答
已选择的解决方案
I have successfully done a repair of this battery, although I do not reccomend this to anyone that has little to no repair experience. If you are willing to do this and are skilled enough to, my advice would be just take your sweet time with the battery. It is flimsy and damaged easily so just be extra careful while doing this replacement. Lord Adhesive really put up a fight for this replacement!
iFixit Replacement Guide
MacBook Battery
MacBook 12" Retina (Early 2016-2017) Battery图片
产品
$129.99
这个答案有帮助吗?
得分 3
评论:
@oldturkey03 Wow, did I get carried away... taking down all the upvotes now :o
完成的
And no, the points really aren’t a big deal anyways. The only thing that counts is happy, satisfied users :)
完成的
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 3
总计 519
