Is there a way to disable battery charging MacBook Pro 2017 TouchBar?
Hi
I have a question is there an option to disable battery charging by software or hardware.
I remember Macbook Pro Unibody 2011 magsafe plug - if you cover the middle pin the battery will no charge, and only the power from the socket will go trough and power the laptop - I used that method when I had that model.
Bu t now I have Macbook Pro 2017 TouchBar and I bought Baseus cable kind of magsafe plug but it has only 5 pins, I tried all variation to cover each pins and all combination, but not success, As I'm not electrician guy I can't test it further.
So my question if some one has that kind of Macbook and Baseus AC Cable with magnetic plug can you test it
Thanks to all
Any one can help me with my question
由 Ivv 完成的
Please does anyone can help me with my question?
由 Ivv 完成的
Hi again is there anyone...?
由 Ivv 完成的
What kind of Baseus AC Cable did you get and why?
由 mayer 完成的
This is the model
https://www.amazon.co.uk/Looyat-Baseus-M...
Thank you
由 Ivv 完成的
