Replaced Retina display, but MacBook won't power up . . .
Recently replaced my early 2015 MacBook's retina display. Press the power button but nothing happens.
Have hooked it up to a 5 watt charger as indicated in one of the comments, but still no results.
Ideas on where to start on a trouble shoot?
Any ideas are welcome . . .
Will
Update (12/19/2017)
Okay! I think the display cable was loose. I reattached it and now it boots normally. Now, there is a milky haze around the border of the screen. Could this be the display cable, or should I get another retina display?
I have rebooted and adjusted display settings . . . External monitor looks fine , , ,
7条评论
What happened to it that caused you to replace the display?
由 mayer 完成的
LCD screen fell. Got cracked after falling. Still worked, but was like looking through a stained glass window. Now won’t power on at all with the new screen.
由 Will Rast 完成的
ANYTHING happen? lights? sound?
由 Aiden 完成的
Just reopened the case. Last night, dead, no sound, nothing. Reconnected the charger and heard a single chime! At least it's something.
由 Will Rast 完成的
It unscrewed the battery retaining screw and pressed the gold LED button , then reconnected the screw,
由 Will Rast 完成的
显示更多的2条评论
