跳转到主内容
Cellular version of Apple's 2nd generation iPad Air. Model A1567.
86 个问题 查看全部
Where to apply replacement adhesive strips?
Hi,
I ordered the battery replacement kit and have the battery replaced, seems to be fine. Cleaned up the edges of the screen and body, now want to install the adhesive strips.
Do I apply them to the screen or the body? There is no guidance within any of the iPad Air 2 guides, and the links referred to above are invalid...?
I know, I know, it seems pretty logical looking at it but I just would like to get it right as there's only one set of the strips...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
I would probably just put them where the original ones were placed before you removed them.
这个答案有帮助吗?
得分 0
添加一条评论
Hilarious.
I'm quite aware of where they go, I'm asking for a hand in the orientation, and if they're easier to install by applying to the the screen or the body first. The guide gives no clues, unlike my iPhone 6s I just replaced the battery on.
The adhesive strips are these ones:
iPad Air 2 Cellular Adhesive Strips
The centre one in particular is not easy to visualize the orientation to the components, the two sides are pretty obvious. Just wondering if there's a diagram somewhere.
I'm sure I can hack and slash my my through, but like all things, there's generally a best way. Was just hoping for someone who's done it before, not a smartass reply.
iPad Air 2 Cellular Adhesive Strips图片
产品
$6.99
这个答案有帮助吗?
得分 0
1条评论:
Did you ever receive an answer to this question, as I have the same question.
完成的
添加一条评论
添加你的答案
winglet69 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 609
