跳转到主内容
Repair guides and support for the Leap, a 5" smartphone running the BlackBerry 10 Operating System.
red light keeps blinking
my blackberry leap just red light blinking?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
my fone says bberror,doesnt wanna switch on
完成的
添加一条评论
2个答案
最有帮助的答案
If the light blinks twice fast then slow 3 times but never turns on, it means the device is soft bricked. This happens when the OS is corrupted or somehow the wrong version of the OS has been flashed on (Like I did). You will need to do a factory reset to bring it back to life.
这个答案有帮助吗?
得分 1
3条评论:
how do u do the factory reset
mine is bricked as u say but i dont know how to flash or whatsoever
完成的
when connected to pc it says no device
完成的
i try the factory reset is not working
完成的
添加一条评论
im assuming the device itself does not boot up for this, because the red light blinks when you have notificationas as well.
If you plug your device in to a PC, and it is recognized, you likely have a screen failure.
If it is not being recognized, then i would start to think you have further issues. Red flashing LED indicates a general hardware failure, which could be most anything. (battery, camera, etc) most commonly however, it is a board level failure.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anthony Enriquez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 3,809
