red light keeps blinking
my blackberry leap just red light blinking?
If the light blinks twice fast then slow 3 times but never turns on, it means the device is soft bricked. This happens when the OS is corrupted or somehow the wrong version of the OS has been flashed on (Like I did). You will need to do a factory reset to bring it back to life.
这个答案有帮助吗?
how do u do the factory reset
mine is bricked as u say but i dont know how to flash or whatsoever
when connected to pc it says no device
i try the factory reset is not working
im assuming the device itself does not boot up for this, because the red light blinks when you have notificationas as well.
If you plug your device in to a PC, and it is recognized, you likely have a screen failure.
If it is not being recognized, then i would start to think you have further issues. Red flashing LED indicates a general hardware failure, which could be most anything. (battery, camera, etc) most commonly however, it is a board level failure.
这个答案有帮助吗?
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 16
总计 3,803
1条评论
my fone says bberror,doesnt wanna switch on
由 azariandhambi 完成的
