跳转到主内容
修理您汽车上的喇叭 音响 CD唱机 插座
247 个问题 查看全部
Why Doesn't my sub work with my headunit
I've recently wired a sub to my car and couldn't get the sub to work the wiring is all good but there is no sound to the sub the amp light is on the settings on my head unit for the sub are all good but still no sound, we tried my brother in laws head unit in my car and the sub worked fine then we tried my head unit in hes car and again no sound in hes sub, we sent the head unit back to pioneer thinking the rca ports were no good got a replacement one and still nothing will i have to get another head unit?
I have the Pioneer avh-295bt
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Hi @bayleighthomass ,
Just verifying that you have double checked that all the settings highlighted in the image below, especially the setting for switching the rear speaker output are correct.
(click on image to enlarge for better viewing)
这个答案有帮助吗?
得分 3
7条评论:
Yes all that is what i have tried to do even with a factory reset and with the old and the new head unit.
完成的
Seems too coincidental to have 2 faulty units.
When you say "the amp light is on" assume that you mean that you have an external power amp for the unit. Is this correct?
To me this means that your connections should be as per the "without internal amp" connections found on p.34 of the guide. Is this how you have it connected?
完成的
Hi I also have a problem, I've try to find subwoofer off and on setting on my 9inch Android head unit but it didn't seem to have it listed on this unit. Place help it would be much appreciated.. Thanks
完成的
@Tow Sok
What is the make and model number of the head unit?
完成的
Pull the top menu down and make sure the amplifier button is highlighted.
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Bayleigh Armstrong 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 57
过去 30 天: 272
总计 22,363
