跳转到主内容
修复你的物品
维修的权力
配件 & 工具
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2244 个问题 查看全部
battery percentage dropping, from 50 to 1
Hi all,
Quick question :
i have an iphone 6s.
battery is sometimes going from 60 or 50 procent to 1 procent.. the 1 procent can bee for several hours..
sometimes i don't have this problem .. strange..
I measured out the battery and that was good. I checked the life of the battery and still above the 90 procent , ( what i figured after the measurement)
what could it be? the IOS 10- 11 "bug" draining the battery or giving faults ?
TIGRIS or TRISTAR?? could that be a possibility ?
what would i do? : hard rest to reset the battery?
Thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
LCD iPhone 屏幕维修套装
预算选项,涵盖在我们的终身保修中。
购买套装
LCD iPhone 屏幕维修套装
削减维修成本,而不是质量。
购买套装
3个回答
最有帮助的答案
I think you are on the right track with thinking U2. Check the charging circuit to see if you are experiencing :Ghost charging" (Fake charging)
这个答案有帮助吗?
得分 3
评论:
Hi,
Now i did a hard reset ( + a software update to IOS 11.2.1 ) and fully charged the phone, i'm trying him out.. and he is working ( discharging) fine... so far..
but : if i check the amperage when charging i see the amperage going from 0.33 tot 1.2 ( continously between those amperages.. ) ...
完成的
I will try to drain the battery now and charge him again..
完成的
battery was empty, the discharging was normal. when i plugged the phone in to charge : it started to charge but the amperage range was between 0.33 and 1.06 amp. after a minute of 3 the amperage was continiously on 0.93 amp.. the fluctuating amperage is not normal i think... and it's not all the time...
any suggestions ?
完成的
添加一条评论
Here's a good thing to check. Make sure to check and see if your iPhone 6s is affected by the battery recall, because that symptom matches completely to the recall. I've attached a link where you can punch in your SN and see. Also, if not affected I recommend downloading coconutBattery and seeing what it says about the number of loadcycles and life remaining. Let me know what happens!
6s Recall Check
这个答案有帮助吗?
得分 0
评论:
Hi Ryan
The phone is not in the range of te "broken" phone's...
I checked the loadcycles ( 256) an life is on 90 procent...
strange ...
完成的
添加一条评论
Have iPhone 6S doing the exact same thing, however I have had the battery changed by Apple a while ago with the recall… I went to apple and they thought it was a software issue (want me to wipe phone & see if it still happens) … funny it’s only started happening after recently updating iOS, currently on 12.3.1… note: it can be showing 1%, reboot it’s back to showing correctly (30% to 50%)… dodgy iOS on on this version phone
这个答案有帮助吗?
得分 0
评论:
It's a bad battery. There's nothing else to it as I do battery replacements on these phones daily on latest iOS version.
If the replacement battery was working for a while then it happened again it's a bad battery.
完成的
添加一条评论
添加你的答案
Kevin D 将永远感激不已
浏览统计数据:
过去的24小时: 14
过去的7天: 87
过去的30天: 405
总计 9,788
