跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
258 个问题 查看全部
Is it possible to add 2 Tb capacity
I wanted to upgrade my Mac"s Storage if really possible to do so can you guys tell me big thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Not sure but I don't see why you couldn't. It would require you to take it apart though. A alternative would be to purchase a EXTERNAL STOREAGE device, and I highly recommend it. You can buy them pretty cheap and just plugs into the USB port and you can access all your files and etc just the same.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Sorry guy Apple uses soldered down flash chips on the logic board which you can't replace. You could buy a replacement logic board which will be quite costly.
If you really need more onboard storage I think you'll want to just buy a new system and sell yours to recover some of the cost.
Review the 配备Touch Bar的15英寸MacBook Pro拆解. Jump down to Step8 & 9 the Orange (8) & Red (9) chips are the Samsung K9PHGY8 flash storage chips.
Samsung does make a really nice external SSD! PC World - Samsung T5 review: USB 3.1 Gen 2 makes the best SSD even better. I would just move all my stuff I don't need all of the time over leaving more space for what I'm actively working on.
这个答案有帮助吗?
得分 3
添加一条评论
possible add even 4 TB. You need unsolder NAND chips Samsung K9PHGY8 and remove it with higher capacity.
You can take it from any Samsung 960- 950 NVME SSD. Install new and then run MPT scan and you will get full 4 TB SSD on your mac. It is regular SSD and it required only replace NAND chips. Controller (B2E) can be used the same.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shohruh Rozikov 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 557
