跳转到主内容
Device and repair guides for the 2016 Samsung Galaxy J5 Prime smartphone, model number SM-G570Y or G570.
79 个问题 查看全部
The back and front camera to my phone isn't working,it says camera fai
My front and back camera is not working,i've tried mostly everything as in factor reset, cleared all my caches etc nothing worked.I think the reason it aint working is because of when the back camera got smashed thats when it started to say camera failed but nothings wromg with the fromt camera its perfectly fine but it just randomly stopped working? Help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hey,
The samsung devices' cameras are usually linked. if something happens to one, it will shut down the App so that you cant use either. Type *#0*#. select front cam, and see if it loads. if it does, then replacing the back camera should fix your issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
crystal Haddon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 126
