跳转到主内容
Second of its generation, released in November, 2011, the Sony SLT Alpha-65V is a SLT (Translucent Mirror Technology) camera with a Sony Alpha/Minolta lens mount.
12 个问题 查看全部
Powers on but won't stay on or doesn't power up at all.
Powers on intermittently but powers off by itself. Confirmed good battery and A/C power supply. Switch, motherboard?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Using the Sony battery, it will power up but will not power down with the switch, nor will it power back up. Screen goes blank. If I release the battery and reinsert it it will power up. I doesn't matter if I use the battery or A/C power adapter. I'm leaning towards motherboard although I have my questions about the On/Off switch.
完成的
添加一条评论
1个答案
最有帮助的答案
Check the internal battery contacts and clean with qtip and alcohol...I have cured a similar problem because oil contaminated the contacts.
这个答案有帮助吗?
得分 1
2条评论:
Thanks but I looked at those. I'm guessing the problem is with the logic board. I will post on here if that is the solution. Thank you.
完成的
Okay..it does sound more like a dry joint leading from battery unit to switch or board....forgot to mention...I take it you are using the bonafide battery from Sony?Because they have a chip inside and third party batteries will power up and the camera software detects they are not Sony and so switch off the camera.
完成的
添加一条评论
添加你的答案
HITGFRY 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 344
