跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1046 个问题 查看全部
Can I use 5S display on iPhone SE?
Yesterday my phone fell down and no display after that. I'm from India and I was not able to find an SE display on eBay. So I was just wondering can i buy a 5S display and use it in my SE because 5S display is available everywhere?
Thanks in advance :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
You can only use the original 5S displays on the SE, you could use 5s aftermarket displays on the SE but it's really a hit or miss, some aftermarkets will display properly on the SE and some don't.
I highly recommend looking or either an original, refurbished 5s screen or aftermarket SE screen.
iFixit also sells replacement SE screens here:
[关联产品丢失或禁用: IF327-005-11]
Here is a guide on how to replace the screen just in case you need it:
iPhone SE 屏幕更换
这个答案有帮助吗?
得分 4
1条评论:
Thank you :)
完成的
添加一条评论
Yes. The 5S and SE screens are interchangeable.
这个答案有帮助吗?
得分 0
1条评论:
Thank you :)
完成的
添加一条评论
You’d better don’t do it. Now the iPhone SE battery replacement is very cheap.
For the reason why you don’t do this, you can read this article: https://www.etradesupply.com/blog/analys...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joshan Joy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 26
总计 9,058
