Won’t go over 2rpm
My 2006 Nissan Altima won’t accelerate over 2RPM, when it goes above that it starts jerking, almost feels like it’s choking. I just changed the Camshaft Sensor because it wouldn’t accelerate when I pressed the gas pedal at all. It now goes, but only until it reaches about 21/2 Rpms. It has a new MAF sensor and just replaced the throttle body sensor. Please help I don’t know what else it could be. I’ve recently learned about something called fail safe mode? Could that be my problem? If so, how do I fix that??
6条评论
I would like to know why my nessan quest is smoothering down and fluddering out at opeerating tempture
由 selfdavid131 完成的
Why can't I get a answer or do you knot know
由 selfdavid131 完成的
If you don't know the answer my queestion just tell me
由 selfdavid131 完成的
Try researching on nissan forums...if you have cleared the codes and gone through the possible usual culprits i suspect it could be a clogged catalytic converter...read this link....
http://x.nissanhelp.com/forums/quest/112...
由 john cordey 完成的
2003 murano revs up in park but wont when put into drive or reverse. what do you think it may be?
由 Eddie jimmerson 完成的
显示更多的1条评论
