跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Repair guides and support for videocassette recorders including Betamax and VHS (Video Home System) players.
23 个问题 查看全部
Where to find a VHS tape cleaner
I am trying to convert my VHS tapes to DVD format and I am looking for a rewinder/cleaner to clean the dirty tapes before I can play them. Kinko had one but is now out of stock. Please help me find such device.
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 8
评论:
I like to buy the tape cleaner
where can i buy
i am from singapore
thank you
+65 98569534
gandhi
完成的
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
3个回答
已选择的解决方案
Here's how to build one using an old vhs player: http://www.instructables.com/id/How-to-B...
High end tape clean & rental: http://www.datadev.com/video-tape-cleane...
Video on how to use the high end: http://www.youtube.com/watch?v=9ft1dHtKd...
eBay listing on cleaning machine: http://cgi.ebay.com/RTI-TapeChek-VT-2100...
Low end cleaning machines: http://www.thefind.com/electronics/brows...
这个答案有帮助吗?
得分 3
评论:
Nice research +
完成的
+ I bet I have a couple in my garage too. Oh the good old times :-)
完成的
添加一条评论
If you don’t plan on using your VCR to record, an easier solution may be to affix a dry piece of lint free gauze over the erase head (to the left of the head drum). That way the tape path passes directly over the gauze and the surface is gently wiped each time it passes through the machine.
For mine I used a 2x2” sterile gauze pad from CVS held in place with small zip ties at the bottom and top of the erase head. Just be careful not to let the pad touch the bottom of the mechanism, else it may wind up wicking some of the oil from the guide track and smearing it against the tape.
这个答案有帮助吗?
得分 1
评论:
Hi, could you email me a picture of what you did to put gauze over the erase head ? stevie1950 @ gmail.com thank you.
完成的
添加一条评论
Hello, we offer an afforable alternative for VHS, VHS-C and 8mm tape cleaning. We use a machine called TapeChek by RTI Industries. This machine is used in BroadCast Studios before a tape is archived. This machine will remove all the dirt and mold that has collected on the tape over the years. It will greatly increase the quality of the VHS image and most importantly, prevent the video-heads on your VCR from getting dirty. You can build your own cleaning device or find a used TapeCheck on eBay but normally they run several hundred to a few thousand dollars. Home made machines will typically rip the tape because the tension of the cleaning pad is very precise. A good alternative is you can mail your tapes to us and we'll clean them at an affodable rate. We also offer high quality transfer services as well. Check out our website at www.mydvdtransfer.com or email info@mydvdtransfer.com
这个答案有帮助吗?
得分 0
评论:
Is it possible to purchase the TapeChek by RTI Industries from you?
完成的
添加一条评论
添加你的答案
Manuel Somohano 将永远感激不已
浏览统计数据:
过去的24小时: 14
过去的7天: 84
过去的30天: 343
总计 25,539
