跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
774 个问题 查看全部
Retina Mid-2015 15" - MacBookPro11,4 (IG) - A1398 won't turn on -
I need help and your expert help. I have a Retina Mid-2015 15" - MacBookPro11,4 (IG) - A1398.
It was working great for the last 2 years without any issues. Suddenly 2 days ago it won't turn it on. The MagSafe adapter light stays Green.
I have made some attempts:
  1. Reset the System Management Controller (SMC) - Using Shift+Control+Option keys and the Power button at the same time. Release all keys and the power button at the same time the MagSafe adapter stay as green NO flash.
  2. Resetting PRAM - Using Command, Option, P, and R keys at the same time. No sound hear the startup. MagSafe adapter stays Green.
  3. I removed the battery connector from the Logical board and after 5 minute re plugged again and tried to open no success MagSafe adapter still stays Green.
  4. 2nd attempt removed the battery connector from the logic board and connected MagSafe adapter it still won’t boot but the MagSafe adapter stays Orange color!
Please give me your suggestion what exactly the fault.
Is it the battery or logic board damage or MagSafe DC-In board?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
When you try to starting the system with the tests you did do you get any startup tones or hear the fan start up?
完成的
I did not on my computer I replaced the battery and still no life
完成的
Im having the same problem friend, in the exact same model, just found your post around If u get any solution let me know please! I will Let u know too if I found something out
完成的
@riccieritibiano - If your system is the same and has the same reaction then the issue is clear you have a logic board problem! As I explained in my answer this will require deeper skills than what you have.
完成的
添加一条评论
1个答案
最有帮助的答案
What I can do is tell you want is working correctly. Your SMC services is! As it knows when you have the battery installed Vs not. So that tells me its not the battery and not the DC-In board. While it may need cleaning it's not the issue here.
That leaves us with a power and/or CPU type of issue on the logic board. At this point I think you've gone as far as you can. So your options are to bring the system into an Apple Store or Apple authorized service center to let them replace the logic board (bench fee and part) or try to find someone with the skills to diagnose what is happening within the logic board and has the skills (micro-soldering) and access to the needed replacement parts.
这个答案有帮助吗?
得分 2
1条评论:
Thank you so much. I will take it to the Apple service. hopefully can be repair the logical board damage otherwise replace new logical board could be costly.
完成的
添加一条评论
添加你的答案
Simos 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 13
总计 1,823
