跳转到主内容
修复你的物品
维修的权力
商店
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
831 个问题 查看全部
in order to best prepare for the mastertech certification
in order to prepare for the master-tech certification...what would be the best advice for someone with limited experience in repairing related electronics devices?
Thank you!
-Oscar
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
2个回答
已选择的解决方案
Pick the device you want to perform the certification exam with and practice the disassembly/re-assembly multiple times until it is a natural progression. I believe that as part of the study guides, they chart out what they will be looking at.
这个答案有帮助吗?
得分 7
评论:
This makes sense, thanks for the advice.
完成的
添加一条评论
I also was once in your place and did not know where to turn and where to start. I was advised to get a Cisco certificate and then I would be able to get a good job. I found a company and recently passed the 2020 Cisco Certification. It was very simple, and most importantly cheap. Other exams are very expensive, and the company I found provides an opportunity to choose the right package. The exam itself went well, online. I was very helped by the company's employees working there. If you are a technician and you are looking for something like this, then I suggest you follow my example.
这个答案有帮助吗?
得分 0
评论:
How can I earn a Master Technician status online? Can I pass tests remotely? I'm a student from Bulgaria. I need at least the recordings of the iFixit MasterTech Webinar:
https://www.essay-have.com
uni-sofia post grad
完成的
添加一条评论
添加你的答案
Oscar Rodriguez 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 2
过去的30天: 9
总计 242
