跳转到主内容
This tablet was released by Asus on July 2013. The model is also called ME173X. The tablet features a 7 in. display microSD card slot, a MicroUSB slot, and a headphone jack.
25 个问题 查看全部
ASUS Memo Pad 7 won't charge
I currently have an Asus Memo Pad 7 that won't charge. I've tried replacing the cord and that doesn't do anything. At one point the tablet finally came back on for about a second and showed the empty battery icon then shut off. I'm thinking that it may be the battery and that I'll need a new one. Any thoughts on how to fix it? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
If you can, take out the battery, then plug in your charger.
I could be wrong but that will directly power the tablet, then it should come on.
If it works, then its a battery problem, if it doesn't work, it could still be a battery problem as Im not sure if that will work.
You most likely just need to buy a replacement battery for the tablet!
这个答案有帮助吗?
得分 2
添加一条评论
Have you tried jumping it with a power supply?? or what volts is the battery reading when you test the leads?
If the battery is reading zero you may need to jump it then check the voltage again.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Peyton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 965
