Samsung smart tv (UE40F6500) keeps turning on and off
After turn-on by remote control TV for a while shows beginning picture on the screen and then it restarts again and again with clicks. Remote control not working. I must unplugg TV manually.
I was trying to run it without connection with other devices (computer, DVD etc.) but without success.
Model: UE40F6500SSXXH. SAMSUNG.
6条评论
@fieloryb what happens when you remove the battery from the remote and just use the buttons on the TV? Does it still do the same thing?
由 oldturkey03 完成的
I only found one button on the back of tv - ON/OFF. This button is not working. I can't turn off TV with this button. I have checked the batteries by using remote control with my mobile phone (it shows how remote control working when you use camera from mobile phone). I think the batteries are OK. Tomorrow I can change them.
由 fieloryb 完成的
@fieloryb remove teh batteries once you turn the TV on. See if that stops your TV from acting up. There is always a chance that the remote is causing this. Right now it sounds like the IR board or the button board that has failed.
由 oldturkey03 完成的
1. I turned on TV by pushing ON/OFF button on the back side of TV without remote control and without succcess.
This failure has been for the first time when I put HDMI plug into computer when Tv was turn on.
由 fieloryb 完成的
My tv automatically started shutting off last night every few minutes now it will not turn back on by using the button or the remote. Is this fixable?
由 Peggy Trejo 完成的
显示更多的1条评论
