apple hi-fi won't work on mains, it only works on batteries.
Hi, my apple hi-fi won't work on mains supply, it only works on batteries. help
Hi @iain_sinclair ,
You will have to open the device and then check the connections from the mains power inlet to the motherboard.
Here is a link that hopefully may be of some help.
If you cannot see (or test, using a DMM- digital multimeter) what the problem is, take some close up pictures of the motherboard and perhaps someone will be able to help you further. Here's how to do that. 在已经存在的问题里加入图片
这个答案有帮助吗?
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 162
Please explain. Do you mean it won't work on wall power?
由 Reed Crosby 完成的
yes, thats correct it won't work on wall power
由 Iain Sinclair 完成的
Have you tried a different outlet?
由 Aiden 完成的
yes tried different wall outlets and different power lead, the problem is with the apple unit.
由 Iain Sinclair 完成的
did you drop it before? anything happen before it broke?
由 Aiden 完成的
显示更多的2条评论
