跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2688 个问题 查看全部
Does iPhone 6s ios 11 activation failure may be related to hardware?
I've updated my iphone 6s to ios 11 since last week. However up until today, i'm still unable to activate, hence use my phone. Restored to factory setting countless time, but still not to avail. Always failed at the "activation server cannot be reached" thingy. I know the server might be busy, but for the whole week? Connected to laptop and itunes, but an error popped up saying that I need to put the simcard correctly (eventhough the phone picked up the cellular signal perfectly) so i cannot activate it using itunes either. So, back to my question, is there any chance that this is a hardware issue? If yes, which part was damaged or need to be repaired? thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Sometime iTunes makes fail to activate use 3utool for activation with supported sim.
这个答案有帮助吗?
得分 0
2条评论:
Thanks. Will try it. Is the software free? Or do we have to pay to unlock all function available?
完成的
Yes that is absolutely free
完成的
添加一条评论
Have you tried updating iTunes? If that still does not work try installing it "manually" http://appldnld.apple.com/ios11.1seed/09... (iOS 11.1 ipsw file for iPhone 6s)
and then use these instructions provided by OSX Daily:
1. Connect your iPhone or iOS device to your computer
2. Select the device in iTunes
3. On a Mac, hold down the “Option” key and then click on “Update”
4. On a Windows PC, hold down “SHIFT” key and then click on “Update”
5. Select the IPSW file you downloaded and click “Choose”
6. Let the iOS device update as usual
这个答案有帮助吗?
得分 0
2条评论:
Hi. Thanks for the response. I’ve already done the steps before. And still can’t activate the phone. Cannot connect to apple activation server.
完成的
Do you have another PC?
完成的
添加一条评论
添加你的答案
Iman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 544
