跳转到主内容
Repair guides and support for LED, LCD, HD and other Vizio TVs.
931 个问题 查看全部
Backlight periodically goes out. What board should I try and replace?
I have a Vizio M502i-B1 with an LTYWRLAR serial number. Occasionally part of the the backlight will go off while the tv is on, leaving a section of the screen dark. If I turn the tv off when this happens and then immediately try turning it back on, the entire backlight stays off. There is still an image on the screen that can be seen if illuminated by a flashlight. At first this happened only rarely but it has become very frequent, often occurring when turning tv on.
Sometimes it can be fixed by unplugging the tv, holding the power button down for 20+ seconds, and plugging it back in. Lately however I have needed to leave it unplugged for 6-8 hours or even overnight.
At first I thought it might just be the LED driver, but after some research it looks like it could be the power board or the main board. The Amazon listing (which was 4 something stars when I got it) has a number of reviews citing a common failure of a fuse on the main board but this does not seem to be my problem.
Does anyone have a suggestion on how to confirm where the issue is and if it is worth trying to find the parts and repair?
Thanks!
Edit 12/13/2017
Adding Photos
I removed the back panel and check ed the connections for the LEDs. Nothing seemed lose, I wiggled and made sure all were firmly seated.
I did not notice any obviously swollen or damaged capacitors.
For kicks and giggles I disconnected the wifi card and removed/reseated the fuse. Its been a few days since I have done this and have not had any problems, though since I didn't really do anything this is likely a coincidence.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
Adam Cain since this turns off and on (even so infrequent etc. ) it is not a fuse situation. That would be a simple go -no go. It does sound like a bad LED array. Check all the connectors to the array and check the power board connector as well. Post some images of your boards etc. with your question. that way we can see what you see. Use this guide 在已经存在的问题里加入图片 for that
这个答案有帮助吗?
得分 2
添加一条评论
My visio tv is working and mounted to a swivel stand so it's not apart for me to take pic's at this time I was trying to figure out the problem so I could fix at a later date
这个答案有帮助吗?
得分 0
1条评论:
truran1963 what is the model of your TV and what have you checked? what are the issues with it?
完成的
添加一条评论
添加你的答案
Adam Cain 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 7,609
