跳转到主内容
Dancing water speakers are computer speakers that feature jets of water illuminated by bright multi-color LED lights.
9 个问题 查看全部
Sound works fine, water won’t shoot up.
I bought a Sylvania water dancing speaker a while ago. Sometimes i have the tendency to leave my speaker on while i run a quick errand. I once left it on, thinking i wouldn’t take long — i was wrong. It stayed powered on several hours without any music playing, so when i got back i noticed the water wasn’t shooting up. Usually all i had to do was power off, & power back on to get the water to work fine again. This time it didn’t, the sound works fine. It lights up, but no water goes up.. Yet it’s still got water in it. Same amount as when i bought it. Can i easily fix this at home? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
评论:
What my water not coming up wen i play music
完成的
Have soundproof dancing water tower speaker, sounds good but the water doesn't shoot out to the music what is wrong?
完成的
Help how do i take it apart.to refill water
完成的
添加一条评论
3个答案
已选择的解决方案
Open it up and use a multimeter to test for continuity of the wiring and see if you may have burned the motor out. Here's how to do surgery on it:
水舞音响重新注水
这个答案有帮助吗?
得分 5
添加一条评论
最有帮助的答案
I bought a Sound Logic Wireless Dancing Water Tower Speaker and i noticed the water didn't shoot up anymore what can I do to fix it at home?
这个答案有帮助吗?
得分 8
评论:
I have the sameone and the water stopped shooting up. Did you ever figure out what was wrong
完成的
same here so I took it apart and everything was naked just fine the motor was no longer turning so now I'm trying to find where I might order a new little motor which is really quite easy to wire into place , just two little sodering spots to connect it but i just started looking for the part
完成的
添加一条评论
My soundlogic BTS-600 won't stay on what's wrong with it I have to hold button for it to stay on
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marely 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 6
过去的30天: 53
总计 9,024
