这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4643 个问题 查看全部
Phone connection sometimes dissapears
So the connection sometimes works, and sometimes it shows "No service" (in the same place) whats the problem? Everything is ok with wifi it does not dissapear.
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
最有帮助的答案
In order of opperations, id look into the following.
Check for Continuity: Does you service only drop in one place? in basements only? Service has difficulty pennetrating concrete and metal. basements, and steel buildings commonly cause service issues.
Call SP: your service provider may be having intermittant issues in your area.
Check SIM: Your SIM card may be failing. Make sure to have your SP change your SIM every year.
Verify Fringe Service Zones: More country like areas have whats known as Fringe Service, which means there is low signal there on the regular.
Factory Reset: Your device software may have become corrupt. A factory reset can fix this issue.
Change Cellular Antenna: Replace the Charge flex w/ Cell antenna. this may be failing.
anything further than this is a board level failure.
这个答案有帮助吗?
按维修分数 1
评论:
Thanks,
P.S. the connection dissapears randomly, where the signal is usually good
absolutely. this is simply a full cellular diagnostic. this goes from least invasive, to most invasive of a repair. i hope it helps you figure out what is wrong
Could it be motherboard fault?
that is the last line on my answer. yes
添加一条评论
添加你的答案
David Jan 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 42
