跳转到主内容
修复你的物品
维修的权力
商店
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
363 个问题 查看全部
Can I exchange hard drive with my other iMac without losing the data?
I have both a 20" and 27" iMac. I want to swap the hard drives and give the other to my daughter. the 20" has a 2tb hd that is partitioned using 1tb for mac and 1 for windows. I don't want to lose my data and wonder if I could just take out the hd and swap it. Any thoughts?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Can you give us the details of the 20" model and the make and model of the HD you have installed.
完成的
Both are iMacs. The 20" is mid 2007, the 27" is mid 2010.
完成的
OK here's the specs for your systems:
iMac 20" 2.4 GHz Core 2 Duo (Mid 2007)
iMac 27" 2.93 GHz i7 (Mid 2010)
We still need your hard drive details.
完成的
添加一条评论
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
跳过升级
通过使用多合一工具包维修可以节省成本。
购买 iPhone 维修工具套装
2个回答
May be here is the solution, please see it....
https://discussions.apple.com/thread/417...
这个答案有帮助吗?
得分 0
评论:
@raichel121 - There's a bit more involved here than what your link implies. Without all of the info we're shooting in the dark here.
完成的
添加一条评论
So far both systems have SATA II (3.0 Gb/s) interfaces so you won't see any speed difference. The 2010 model uses a custom thermal sensor cable for the systems SMC services. Unlike the 2007 model. Here's the IFIXIT guides for reference:
Review Step10 in the iMac Intel 27" EMC 2390 Hard Drive Replacement guide. Without knowing your exact drive we can't aim you to the custom cable you need as each supplier of HD's have a different cable your other option is getting this OWC adapter: OWC In-line Digital Thermal Sensor for iMac 2009-2010 Hard Drive Upgrade
The last issue here is the OS your drive has on it needs to be one that the 27" model supported older OS's may not allow the system to boot. You'll want to create an OS installer drive following this guide: How to create a bootable macOS Sierra installer drive. So you can re-install the best OS for your system. I do recommend you boost your systems memory to 8 GB or more.
iMac Intel 20" EMC 2133 and 2210 硬盘图片
指南
iMac Intel 20吋“EMC 2133和2210 硬盘更换
难度:
中等
1 hour
iMac Intel 27" EMC 2390 硬盘图片
指南
iMac 因特尔 27" EMC 2390 硬盘更换
难度:
中等
40 minutes - 2 hours
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robert C Rivera 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 47
