跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2191 个问题 查看全部
iPhone 4S shows red battery and will not charge after changing battery
I changed my iphone 4S battery with an ifixit battery. The repair went fine. I was letting the battery drain until 10% as instructed. When I went to charge the iphone, the battery does not appear to be charging and all I get now is the red battery symbol with the plug that flashes 2 times and then goes black. The only way I get this screen is when I try to do a hard reset and hold it for 10 seconds. I have looked at the port for lint, but none there. Changed to a brand new cord, still the same. Tried plugging into the computer and it is not recognized and still does not come on. I have tried other cubes and plugged into the wall and still nothing. I do not know what else it could be. I could change out the port, but I do not want to just keep throwing money at this phone. Others have said it could be a bad battery. Any suggestions would be greatly appreciated. God Bless You!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
What was wrong with the original battery?
If it was showing a low battery logo with a iPhone 4 charging cable showing up on the bottom of the screen then you have a bad charging port.
这个答案有帮助吗?
得分 1
1条评论:
The original battery nothing worked just black. With the new ifixit battery in the iphone, it has a charge, about 50% and I used the iphone until it got down to 10% as the instructions said to do. When I plugged the iphone into the cord, I did not get the charging symbol to know that it was charging and the screen was blank. I read forums on the net to see if I could find out a problem. Still now the screen is black. Only when I hold the on and home button for about 10 seconds, then the screen comes up with the red battery, that will blink twice, and the cord that says I need to plug the iphone in to charge the phone. After the red battery blinks twice the screen goes black again.
完成的
添加一条评论
Having recently tried no less than four replacement batteries all which initially powered the phone but then would not recharge, I solved the "iPhone 4s will not charge"issue by:
1. spraying a small amount of WD40 into the iPhone's charging connector to chemically clean the connections
2. connecting and disconnecting a charge lead a number times to clean the contacts mechanically
As you may already know, WD40 is a water displacement product used for cleaning electrical contacts among other things. It worked perfectly in my case.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dave Brenneman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 4,595
